فارس عبد العزيز
2024-09-10 14:46
Is there a modification available for the 2023 model 1.6T where the middle part of the through-type taillight doesn't light up?
عبدالله ابيض
عبدالله ابيض2024-09-13 15:31
There are modifications. You can go give it a try!
محمد خالد
محمد خالد2024-09-12 18:23
Yes, it can be modified.
Have you experienced a situation where the welcome light on the driver's side doesn't light up, but the other three doors do?
I have a 2019 GS5 Elite version. Sometimes the central control screen doesn't power on, but the air conditioning works fine. The reverse radar is not usable, and the central control screen doesn't light up. Does anyone know why this is happening or has anyone else encountered this issue?
The engine warning light is on, and the idle seems unstable. The speed can still go up, but it doesn't accelerate as quickly as before. Could it be a problem with the throttle? Any insights?
The rear tail light on the driver's side doesn't light up when I brake. I just replaced the bulb half a month ago, and now it's not lighting up again. The previous inspection said it wasn't a bulb issue. Has anyone else experienced this? What's the problem?
Does the center part of the taillights light up on your luxury version at night, or only the sides?
For Comfort model users, do your through-type taillights light up as a strip at night, or only on the sides?
When braking, does this taillight light up? After the dashboard is powered on, all the fault codes light up, but they all disappear once the engine starts. Is this situation normal?
Has anyone added through-type taillights to the 2023 Villa model?
Is it normal for the right taillight not to light up?
JETOUR Jetour X90
Jetour X90AED 89,000 ~ 115,000Gasoline & Petrol
