سلمان كلثوم
سلمان كلثوم
Aug 23
In the 2019 JETOUR X90 Enjoy Edition 6-seater with a 6DCT dry dual-clutch transmission, currently at 120,000 kilometers, an issue has been occurring since around 90,000 kilometers. When starting the car cold, everything is normal during acceleration. However, after driving for about half an hour and the engine warms up, when stopping or waiting at a traffic light and then trying to accelerate again, the car doesn't respond to the throttle. If you press the throttle harder, the engine stalls. When you feel the engine shake while pressing the throttle, if you release the pedal immediately and then press it again, the car can start moving, and everything works normally after that. There are no fault codes detected by the computer, and the spark plugs have been replaced. The engine checks out normal at the 4S shop. I'm seeking advice from experts on how to resolve this issue or if any fellow JETOUR X90 owners have experienced a similar problem and how they got it fixed. Thank you very much for your help!
سلمان زبيدي
سلمان زبيدي2024-11-24 23:07
Did you find your problem?
سلمان زبيدي
سلمان زبيدي2024-11-24 23:06
I have a five-seater, and now it struggles to accelerate at the start. It feels powerless, and after two or three seconds, it reacts a bit but then jerks. I can't start on a slope, but once the speed picks up, it runs normally. I really regret buying this car with a dry dual-clutch transmission. I can't find the problem at all. I even went to the repair shop and changed the fuel pump, but it didn't help.
عبد العزيز خليف
عبد العزيز خليف2024-09-18 14:01
I've never encountered this before, but doesn't the description sound like the fuel is mixed with water? [I want to be alone]
عبدالله ابيض
عبدالله ابيض2024-09-13 15:48
If the 4S shop doesn't work, how about considering a refurbished one?
علي حرب
علي حرب2024-08-24 01:00
[I just want to be quiet] There's nothing wrong, why repair it?
When the car is in D gear at idle, it feels weak (like an ant crawling), but when you press the accelerator, it becomes normal. In reverse gear, it doesn't move at all unless you press the accelerator. The car is a 2016 Haima S5.
Has the Jetour X90 2024 model been released?
I have a 2023 Jietu X90 Zilong Changsheng version. When starting and accelerating, the engine roars loudly. Is it the same for everyone? There's no engine noise when it's idling, but as soon as I press the accelerator to start, the engine sound is quite loud.
What do you think about the Jetour X90 Kirin 1.6T?
When driving at low speeds over rough roads or speed bumps, and then accelerating, the RPM between 1100 to 1500 feels like it's cutting out. Once the throttle picks up, everything returns to normal.
When starting the Jetour X90 Zilong, the throttle response is decent, and the power comes immediately. However, after reaching 70 km/h and releasing the throttle, if you want to accelerate again, there's a 1-second delay before the power suddenly kicks in. This isn't the same as getting power instantly when you press the throttle. What's going on here?
I have a 2023 JETOUR X90 Zilong. When driving at low speeds, if I press the accelerator, the car suddenly surges forward. However, after reaching 70 km/h, if I release the accelerator and then try to accelerate again, there's about a 2-second delay before the car suddenly surges forward. Is this throttle response delay a common issue?
What is the situation with the abnormal noise from the water pump of the Jetour X90 Wilderness Edition 1.6T? Is it normal?
Will the 2024 JETOUR X90 PLUS automatically release the electronic parking brake when the accelerator is pressed during start-up?
Jetour X90
Jetour X90TBDPetrol
