عبدالله زبيدي
2024-02-19 15:36
I have a 2023 Jietu X90 Zilong Changsheng version. When starting and accelerating, the engine roars loudly. Is it the same for everyone? There's no engine noise when it's idling, but as soon as I press the accelerator to start, the engine sound is quite loud.
عبد العزيز زياد
عبد العزيز زياد2024-02-22 19:51
The engine not making much noise during acceleration might mean it's broken [I want to be quiet].
حسين عدي
حسين عدي2024-02-21 10:31
The 2022 model has been running for almost two years now, and it has reached 40,500 kilometers. The idle noise is very noticeable.
عبدالرحمن مستنصر
عبدالرحمن مستنصر2024-02-20 23:54
It seems like you're finding problems where there aren't any. The engine definitely roars when accelerating from a start. Many drivers actually enjoy the roar of the engine when accelerating. Is this your first car?
Will upgrading the system fix the freezing of the central control screen in the 2023 X90 Zilong Changsheng 7-seater?
When I release the accelerator on my 2023 Vito with seven seats, there's a loud buzzing noise. Has anyone else experienced this issue?
Hey car enthusiasts, any idea why the 2023 X90 Zilong Changsheng edition's hazard lights automatically flash 10 times after turning off the engine?
Does your engine also make a loud noise when the RPM reaches 2000? Especially when going uphill, all I can hear is the roar of the engine.
When starting the Jetour X90 Zilong, the throttle response is decent, and the power comes immediately. However, after reaching 70 km/h and releasing the throttle, if you want to accelerate again, there's a 1-second delay before the power suddenly kicks in. This isn't the same as getting power instantly when you press the throttle. What's going on here?
I have a 2023 JETOUR X90 Zilong. When driving at low speeds, if I press the accelerator, the car suddenly surges forward. However, after reaching 70 km/h, if I release the accelerator and then try to accelerate again, there's about a 2-second delay before the car suddenly surges forward. Is this throttle response delay a common issue?
How many meters does it take to start with a 2024 Jietu X90 automatic?
The 2023 model 3.0 is shaking a lot at idle, and there's a buzzing noise when starting. Does anyone know what might be causing this?
Will the 2024 JETOUR X90 PLUS automatically release the electronic parking brake when the accelerator is pressed during start-up?
JETOUR Jetour X90
Jetour X90AED 89,000 ~ 115,000Gasoline & Petrol
