عبدالله زبيدي
Jun 8
I have a 2023 JETOUR X90 Zilong. When driving at low speeds, if I press the accelerator, the car suddenly surges forward. However, after reaching 70 km/h, if I release the accelerator and then try to accelerate again, there's about a 2-second delay before the car suddenly surges forward. Is this throttle response delay a common issue?
Comments( 8 )
My 2007 S40 has power throughout the car, but there's no response when I try to start it. I'm not sure what the problem is.
Is it normal for a 2015 model 2.0L automatic transmission car to have the RPM around 1300 at 60-70 km/h, and when slowing down for a turn then accelerating again, the RPM suddenly rises and acceleration is slow, with the RPM at 1600 to 1700 at 60 km/h and not dropping, and sometimes after turning off the engine and restarting it behaves normally?
Has anyone experienced a delayed throttle response while driving? My car often has this issue, and it's getting worse over time. When I first bought the car, the delay was almost a quarter of a second, and now it's almost two seconds.
4Hey car enthusiasts, have you ever experienced a jerky start, where you accelerate but the car doesn't move immediately, and then suddenly jumps forward after a few seconds?
5When stuck in traffic, frequently braking and accelerating might lead to no response from the gas pedal. You'll need to idle forward a bit before the accelerator responds, or you can restart the engine to temporarily fix the issue.
6I have a 2023 Jietu X90 Zilong Changsheng version. When starting and accelerating, the engine roars loudly. Is it the same for everyone? There's no engine noise when it's idling, but as soon as I press the accelerator to start, the engine sound is quite loud.
72010 Peugeot 307, automatic transmission. Why does it make a squeaking sound every time I accelerate at low speed and then suddenly release the accelerator?
8When starting the Jetour X90 Zilong, the throttle response is decent, and the power comes immediately. However, after reaching 70 km/h and releasing the throttle, if you want to accelerate again, there's a 1-second delay before the power suddenly kicks in. This isn't the same as getting power instantly when you press the throttle. What's going on here?
9I have a 2023 JETOUR X90 Zilong. When driving at low speeds, if I press the accelerator, the car suddenly surges forward. However, after reaching 70 km/h, if I release the accelerator and then try to accelerate again, there's about a 2-second delay before the car suddenly surges forward. Is this throttle response delay a common issue?
10Why does my 2021 manual Santana sometimes have no response when I try to start it, requiring several attempts to ignite?
