After turning off the engine and locking the car, the driver's side window automatically rolls down. While driving, the driver's window button is sometimes responsive and sometimes not. Whether raising or lowering, once the button is pressed, the window moves directly to the bottom and won't stop in the middle. After reaching the end, you can still hear a clicking sound inside the door panel. Is the window button broken? Could you provide a replacement tutorial, preferably with a video?
Is your CarPlay music playback smooth? How do you fix any issues? Also, the automatic lock/unlock feature sometimes doesn't work properly, which is frustrating. Additionally, after turning off the engine, the power cuts off immediately, so I can't close the windows if I forget. Lastly, when starting the car, I have to manually turn on the central control. Is this a settings issue on my part? How do you all deal with these issues? Or am I the only one experiencing them?
After washing the car, the front door windows won't roll down. The buttons aren't responding. Has anyone experienced this before?
My 2013 Sharan's electric door sometimes won't close by itself, and the button doesn't work either. After disconnecting and reconnecting the power, it works again. Does anyone know the reason?
4When the suspension is raised to its highest level, after parking and turning off the engine, the vehicle sometimes lowers to a normal height. I haven't activated the easy entry/exit feature, and it doesn't lower immediately after turning off the engine. Sometimes it doesn't lower at all, while other times it lowers on its own.
5To reset the tire pressure light on the MG GS 4WD, follow these steps: 1. **Check Tire Pressure**: Ensure all tires are inflated to the recommended pressure levels. You can usually find the recommended pressure on a sticker inside the driver's door or in the owner's manual. 2. **Drive the Car**: Sometimes, simply driving the car for a few miles can reset the tire pressure monitoring system (TPMS) if the tires are properly inflated. 3. **TPMS Reset Button**: Some models may have a TPMS reset button. Check your vehicle's manual for its location and instructions on how to use it. 4. **Professional Assistance**: If the light remains on, it might be necessary to have the system checked by a professional, as there could be an issue with the TPMS sensors. Please follow these instructions based on your specific vehicle model and refer to your owner's manual for more detailed guidance.
6Are there any owners of 2019 two-wheel drive or four-wheel drive luxury models here? I have a question. For models where only the driver's window has the one-touch up/down feature, can you long-press the lock button on the key to raise the windows? Can this be upgraded at the dealership? My 2019 four-wheel drive luxury model can only close the sunroof with the key, not the windows.
7After turning off the engine and locking the car, the driver's side window automatically rolls down. While driving, the driver's window button is sometimes responsive and sometimes not. Whether raising or lowering, once the button is pressed, the window moves directly to the bottom and won't stop in the middle. After reaching the end, you can still hear a clicking sound inside the door panel. Is the window button broken? Could you provide a replacement tutorial, preferably with a video?
8Hey guys, I'm having an issue with my car's driver door. Sometimes I can't open it from the inside. I have to use one hand to pull and the other hand to pull the door latch to open it. Plus, there's a clicking sound when I pull the latch. Any idea what's wrong?
9Why does the driver's door not open with the key unlock button after locking the car from the outside, while the other three doors can be opened?
10The front windows of the Jetour X70 cannot be opened, and the horn alarms when the car is locked with the remote. When the unlock button on the remote is pressed and held, only the rear windows open, while the front windows do not respond. I had this issue repaired at the 4S shop before, and they said it was related to the fuse. However, the problem has occurred again just two to three months after the repair.
