When driving on rough roads with a 2018 Jetur X70, there's a "dong dong" sound from the front, but can't find the cause. What could be the issue?
What could be causing the engine to make a ticking sound?
Does the Acura RDX have a towing point? I can't find it, neither at the front nor the back.
When driving over slightly rough roads, there's a clanking noise from under the front wheels, like metal hitting metal. Has anyone else experienced this?
4Is there any fellow Haval owner experiencing a clunking noise from the front right shock absorber when driving on rough roads?
5How do I turn on the front fog lights on the 2021 model 95? I can't find it.
6For a 2016 model, does it need a timing belt replacement? At how many kilometers should it be changed? Also, when driving on rough roads, there seems to be a "thud" sound from the suspension. It has just reached 80,000 kilometers now.
7Why can't I play music from a USB on my Chery Jetour X70 Plus?
8What could be causing a clunking noise from the left front wheel on a 2013 Peugeot 508 2.3 while driving?
9I got my car in August 2024, and when the left wheel goes over rough roads, there's a metallic clanking noise. What could be the issue?
10When driving on uneven roads, there's a jingling noise coming from the rear of the car. But when the windows are closed, the sound can't be heard. What could be the issue? I suspect it might be the silver trim at the rear.
