The engine temperature is too high, and it won't start.
When driving, if the electronic fan does not start at high speed after turning on the air conditioning and the water temperature is high, how can this be resolved?
11-year manual transmission, car powers on but won't start. Any experts here to help? 😊 Checked the fuse box too. 😢
How to solve high water temperature issue in V73?
42017 model 1.4T, now the temperature is around 3°C. When I start the car, the RPM is at 1200, and when I start driving with a cold engine, the RPM goes above 3000 before it shifts gears, and it feels shaky. Do you guys experience this too?
5Why does it show high coolant temperature at startup? Unable to start.
6The engine temperature is too high, and it won't start.
7The oil price is too high.
8The engine won't start, and the EPC, battery, and engine fault lights on the dashboard are all on. What could be the reason?
9The car won't start, and the EPC, battery, engine, and malfunction indicator lights are all on. What could be the reason?
10If you leave the key in the ignition for too long without starting the car, it won't start. If the key is in the ignition for more than half a minute without turning the engine on, the key becomes stuck and you have to turn off the power and try starting the car again.
