عمر حكيم
2024-04-20 12:26
The Check Engine light on my JETOUR X70 with 40,000 kilometers suddenly came on.
عمر حكيم
عمر حكيم2024-06-22 23:29
I've had my Jetour X70 for less than 4 years, and suddenly it won't start after refueling. I have to floor the gas pedal for a minute, but it starts normally otherwise.
علي رائد
علي رائد2024-05-14 22:02
Check it first, sometimes it's a wiring issue, not necessarily an engine problem.
خالد أنس
خالد أنس2024-05-14 11:50
No pictures, no truth, and not even a verified car owner.
سلمان أنور
سلمان أنور2024-05-05 10:45
My light is on too!
Has there been a situation with your JETOUR X70 where the battery runs out of power even before reaching 500 kilometers?
My car has done 40,000 kilometers, and I feel like there's an issue with the transmission. Have any of you changed the transmission oil or had it checked? Looking for advice.
Does the 2020 model of Jetour X70 have an automatic flashing function, like hazard lights, when braking hard at high speed?
I just got a 2011 Mazda 5 a couple of days ago. After only two days, the check engine light came on with the code P2177. Can anyone help explain this?
Why can't I play music from a USB on my Chery Jetour X70 Plus?
After the light came on, I drove 20 kilometers and then refueled 65 liters. I'm starting to doubt if my fuel tank is actually 80 liters.
What do you think of the performance of the Jetour X70 Plus Champion Edition with the 1.5T engine?
JETOUR Jetour X70
Jetour X70AED 73,000 ~ 79,000Gasoline & Petrol
