علي طيب
2023-02-26 18:15
Hi friends, how long can your X70P battery last on standby when fully charged?
Comments( 8 )
سلمان رأس
سلمان رأس2024-11-26 03:07
I drive once every 20 days.
أحمد منذر
أحمد منذر2023-02-28 11:25
"I want to be alone for a while."
سلمان حارثي
سلمان حارثي2023-02-28 09:54
Hello, it's recommended that if you're not using your vehicle for an extended period, you disconnect the negative terminal of the battery. This can help prevent the battery from draining and getting damaged.
زيد دين عبدالرحمن
زيد دين عبدالرحمن2023-02-28 09:33
For me, at most, I'd let it go for a month. It's not a big deal. The main issue is that you often drive short distances, so the battery doesn't get fully charged, leaving it undercharged. This is really bad for the battery. My old car had the same problem. The most frustrating time was when I was on the highway, and at the service area, the battery wouldn't charge at all. Even when a kind driver tried to jump-start it, it didn't work. I ended up having to replace the battery for 900 bucks at the service area, which was such a rip-off. If the battery gets undercharged a few times, it becomes really hard to charge it again. I'd recommend replacing it so you don't end up like me [I want some peace].
محمد مدرسي
محمد مدرسي2023-02-28 08:43
My car has been sitting for over 20 days and now it has no power at all.
نايف رامي
نايف رامي2023-02-27 08:33
I once didn't start the car for seven or eight days, then asked a family member to start it and let it idle for ten minutes.
فهد راضي
فهد راضي2023-02-26 22:27
Ten days to half a month is not a problem!
عبدالرحمن سلطان
عبدالرحمن سلطان2023-02-26 19:29
I’m not sure, leaving it for half a month is fine, but I haven’t tried for longer. 😄😄
