حسين زياد
2024-06-11 22:07
Jetur X70, 2020 model. I started having a coolant leak, and when pressure was applied, the leak point was found. The four-way valve was replaced, and the heating pipe and water inlet pipe were tightened. It was also discovered that the water pump was leaking, and eventually, everything was replaced. However, after refilling the coolant, the mechanic found that the engine temperature was high, but it drops as soon as the heater is turned on. They spent half a day but couldn't find the problem, and the car not being fixed has caused a lot of issues. Have you encountered this before? How did you handle it?
عبدالله هاماوي
عبدالله هاماوي2024-07-16 19:29
Looks like the pot 🏺 is broken, right? Mine is broken too and hasn't been replaced yet. [I want to be alone]
نايف أزهر
نايف أزهر2024-06-14 21:10
It's indeed difficult to solve the issue of this car's high temperature.
I have a 2011 SsangYong Korando, 2.0T, two-wheel drive version. When idling while parked or in drive, the car shakes and eventually stalls after a while. I've replaced the EGR valve, but it still shakes. Checked the fuel injectors, no error codes found. There's no SsangYong service center here anymore, and I'm really stressed out. Desperately seeking help!
The air conditioning isn't cooling. I checked the pipes and found no leaks. However, after adding refrigerant, it was gone in less than two months. For an 11-year-old imported Mazda CX-7, what usually causes this issue?
The mechanic said my radiator is leaking, but I haven't noticed any decrease in the coolant reservoir, and there haven't been any warnings on the dashboard. Should I replace the radiator now? Thanks for any advice!
Has anyone experienced water leaking onto the passenger side from the AC? The AC drain pipe isn't clogged and it's draining water. Could it be that there's water inside the evaporator box?
I bought the 2019 Bestune T99 in September 2020. Since it was my first car purchase, I lacked experience and fell into many traps. Besides having many minor issues, I later discovered several parts were damaged. The tires were previously used, which immediately made me suspect that this car was probably a test drive vehicle. And I was right. A few days ago, I went to replace the turn signal lights and found that the wiring inside had been reconnected, and the connections were poorly done. Moreover, the production dates of the left and right turn signals were almost a year apart. (Cars from the factory have uniform dates.) After all these years, it's impossible to explain this to the dealership now! I hope everyone pays attention to details when buying a car to avoid being deceived.
2013 Peugeot 3008 1.6T version is consuming coolant too quickly, but no leaks can be found. Does anyone know what might be going on?
I got a 2021 Murano in July 2021, and just recently on a long drive, I found that the AC was blowing hot air with no cooling. After visiting the repair shop and refilling the refrigerant, the AC started cooling again. The car is just 3 years old, is it normal for the refrigerant to run out so quickly, or could there be a leak?
JETOUR Jetour X70
Jetour X70AED 73,000 ~ 79,000Gasoline & Petrol
