Is there a reserved harness interface for the reading lights on your 2020 X70? I want to install a dashcam but couldn't find it after looking for a long time. Does anyone else have it?
I got my car at the end of last year, and now every month there's always a day or two when the windows automatically roll down without any warning. Has anyone else experienced this? I went to the 4S shop, but they couldn't find any issues. [Cool]
How do you read your water temperature gauge? I couldn't even find where the gauge is.
How do you guys install your dashcams? Is there a power outlet reserved near the car's rear-view mirror?
4My car is 3 years old and sometimes it shows a right front indicator fault, but then the warning disappears. I've had it checked at the shop, but they couldn't find the cause. Has anyone else experienced a similar issue?
5Can the 2020 T99 have a dashcam installed by oneself?
6Is there a reserved harness interface for the reading lights on your 2020 X70? I want to install a dashcam but couldn't find it after looking for a long time. Does anyone else have it?
7Jetur X70, 2020 model. I started having a coolant leak, and when pressure was applied, the leak point was found. The four-way valve was replaced, and the heating pipe and water inlet pipe were tightened. It was also discovered that the water pump was leaking, and eventually, everything was replaced. However, after refilling the coolant, the mechanic found that the engine temperature was high, but it drops as soon as the heater is turned on. They spent half a day but couldn't find the problem, and the car not being fixed has caused a lot of issues. Have you encountered this before? How did you handle it?
8Noise issue, seeking advice from experts. I have a 2020 1.6 manual ASX. When driving on highways or national roads, once I go over 100 km/h, there's a knocking sound from the back after a bump, like a board isn't fixed properly. Yesterday, it was really annoying while on the national road. Even after stopping the car and restarting it, the knocking sound was still there. When I got home and tested it again, it was gone. This has been happening for a while, and I've checked multiple times but couldn't find the cause. Considering yesterday's situation, I suspect it might be an exhaust pipe issue. Has any fellow car owner experienced a similar problem?
9Hey fellow car enthusiasts, I've got a 2023 2.0T RuiShang and there's a strange noise when starting up. After starting, there's a "boom" sound after a little while. It happens every time, and it seems to be coming from near the driver's side door, around the left front wheel area. I've taken it to the dealership, but they couldn't find the cause. Has anyone else experienced this?
10Does your car make a creaking noise on bumpy roads? I took mine to the service center, but they couldn't find anything. Does anyone else have this issue?
