حسين جعفري
Nov 4
Hello fellow car enthusiasts, does anyone know how to open the fuse box in the car to replace a fuse? The 12v power under the dashboard isn't working, so I want to check if the fuse is blown.
My radio keeps losing power, could you tell me where the fuse box is?
The self-check light on the Accent's dashboard isn't lighting up? And there's no engine warning light either.
Who has a complete picture of the engine bay fuse box? Mine is not clear, and I think the headlight fuse is blown. It's not working, urgent!
411-year manual transmission, car powers on but won't start. Any experts here to help? 😊 Checked the fuse box too. 😢
5The cigarette lighter fuse for the 1819 model of Yuxiang is located in the fuse box. You can usually find the fuse box under the dashboard on the driver's side or in the engine compartment. Please refer to the vehicle's manual for the exact location and diagram of the fuse box.
6Why is there a buzzing sound coming from the fuse box and then the headlights turn on and the wipers work by themselves?
7To check the fuse for the front left low beam on a Skoda, you should first refer to your vehicle's owner's manual. The manual typically contains a diagram showing the location of the fuse box and details about each fuse. In most Skoda models, the fuse box is usually located either under the dashboard on the driver's side or in the engine compartment. Once you locate the fuse box, look for the diagram that indicates which fuse corresponds to the low beam lights. Make sure to replace any blown fuse with one of the same amperage.
8Where do you power your dashcam from? If you don't need parking monitoring, is it better to take power from the reading light, OBD, or the fuse box?
9Why isn't the left side of the lights on my Kia Cerato working when I lock the car? Is it a blown fuse or a burnt-out bulb?
10Is the left front and rear lock lights of the Kia Cerato not working because the bulb is broken, or is it a blown fuse? Does anyone know?
