Does your car veer to the right when you let go of the steering wheel?
At the end of November, I replaced the control arm, steering rod, and axle assembly. Now the steering feels very light. When going over bumps, the steering wheel moves erratically. If I accelerate a bit aggressively, the steering veers off. Can someone help me out? [crying]
How to fix the steering wheel pulling to the right?
Does your steering wheel shake a lot when you brake at speeds over 60? Have any of you experienced this phenomenon?
4Does your Alto automatically return to the center when you turn the steering wheel?
5Does anyone else have the issue of the BYD e2 veering to the right when accelerating?
6Do you have the issue where the steering wheel is straight, but the car veers to the left?
7Does your car veer to the right when you let go of the steering wheel?
8Does your car's steering wheel automatically return to center when you make slight adjustments at high speeds? When you make minor adjustments with one hand, do you feel a lot of resistance?
9When you hear a clunking sound after turning the steering wheel, what's going on?
10I recently bought the 2024 Tiida Intelligent Edition and it's my third time driving on the highway. When I reached 130 km/h, I noticed that after exiting the highway, the steering wheel needs to be slightly turned to the right to go straight. If I keep it centered, the car veers to the left. Is this normal? Also, is getting a wheel alignment expensive?
