نايف عباد
2024-05-11 21:51
Do any of you use a USB drive to listen to music? Does the USB drive need to meet certain requirements? Why can't the songs I downloaded on my previous USB drive play? I used a card reader with a memory card, and it worked before, but now it always switches back to the radio interface.
خالد أنس
خالد أنس2024-08-02 00:02
Was your last choice in-car media or Bluetooth music?
Why can't the 2016 S5 detect the USB drive, and where can an SD card be installed?
Why does the car disconnect when listening to music via a USB drive? How can this be resolved?
Can I use a USB drive to listen to music?
Can the 2019 Changan Yuexiang Manual Comfort model use a USB flash drive?
There could be several reasons why the music USB drive isn't responding when plugged into the USB port of your car or other device: 1. **Compatibility Issues**: Some car USB ports or devices may have compatibility issues with certain USB drives or file formats. Ensure the music files are in a supported format like MP3. 2. **File System Format**: Check if the USB drive is formatted in a compatible file system, such as FAT32 or exFAT, which are commonly supported by car audio systems. 3. **USB Port Problem**: The USB port itself might be faulty. Try plugging the USB drive into a different port if available. 4. **USB Drive Issue**: Although it works on your computer, there might be an issue with the USB drive that affects its performance in other devices. Consider testing with another USB drive. 5. **Device Settings**: Check the settings of the device you're plugging the USB into. Some settings might need to be adjusted to read external USB storage. 6. **Power Supply**: Ensure that the device has enough power supply to read the USB drive, especially if it's an older model or if there are multiple devices connected. Try troubleshooting with these suggestions to identify the cause of the problem.
Can the Cetus car play music online, or can it download apps to play music, or is it only possible to use a USB drive?
Is the 1.4T Superb from 2024 using a card slot or a USB drive for music playback? Could anyone let me know? Thanks!
What formats does the USB interface support? I'm planning to use a USB drive to play lossless music, and I'm not sure if it supports APE format.
The 2020 model only has one USB port. If you plug in a USB drive to listen to music, you can't connect the car kit. The USB extension ports you bought aren't working, and the USB in the armrest cigarette lighter also doesn't support USB drive for music or connecting the car kit. Do you have any suggestions for using both the USB drive for music and the car kit simultaneously?
JETOUR Jetour X70
Jetour X70AED 73,000 ~ 79,000Gasoline & Petrol
