Did the mechanic place the jack on the edge of the bodywork when your tire was punctured, causing it to deform? Has this happened to you as well?
The Vellfire has been driven over 40,000 kilometers, and there's a lot of noise coming from the rear tires. Upon inspection, the inner tires are worn, and both tires are the same. What could be causing this?
Has anyone here upgraded their tires and rims from 205/55R16 to 225/45R17? What's the process and how much did it cost? Thanks!
What tires did you guys replace on your ASX? I've got a 1.6 manual that's seven years old, and the original Dunlop tires have aged.
4Has any owner of the 2019 model replaced their tires? Did anyone in the forum also switch to Continental tires?
5HS 30T 2WD, when driving on the highway, the steering feels sticky and doesn't return to the center, making it tiring to constantly adjust. This doesn't happen at low speeds or in hot weather. Has anyone else experienced this? How did you solve it? Some say it's an issue with the steering gear and needs a full replacement—is this true?
6Have you guys changed your tires around 50,000 km? If so, what did you switch to?
7Did the mechanic place the jack on the edge of the bodywork when your tire was punctured, causing it to deform? Has this happened to you as well?
8Is your 2021 GAC GS4 Tech Edition still powering the screen after the engine is turned off, taking about two minutes to cut the power? Has this change happened to you as well?
9Has anyone experienced tire deformation with the Lingfang 2.0 Premium version after driving about 12,000 kilometers?
10The steering wheel is crooked 🤦♂️. Even after doing a wheel alignment, it can't be fixed. The mechanic said it's caused by a deformed lower control arm?
