علي سيف
2021-12-11 15:10
Why is the tire pressure warning light still on even though the display shows 220? It's been a week and it hasn't turned off.
لطيف عبد العزيز
لطيف عبد العزيز2022-10-19 10:37
Did you install the dashcam yourself and connect the ground wire to the passenger side?
عبد العزيز صادق
عبد العزيز صادق2022-08-29 18:54
Why does yours have this feature and mine doesn't?
محمد يحيى
محمد يحيى2022-07-25 00:10
Same experience. Refilled the air to about 250 and it was sorted.
It's been two years of following, but it still hasn't been released.
The tire pressure monitoring system suddenly gave an alert, but the tire pressure is normal. I drove 100 kilometers and it still hasn't reset. How can I fix this?
How to reset the tire pressure display?
Does Cetus Luxury have a tire pressure display?
How do I reset the tire pressure after a repair? It still shows low pressure on the right rear tire.
How can I change the display on the left side of the dashboard screen? Mine always shows a car model, but I've seen others display tire pressure.
Today, I inflated the tire and reset the tire pressure, but it's still showing "monitoring" even after driving up to 25 km/h. I took it for a spin, but it didn't help.
Is the Nissan X-Trail EP using a direct or indirect TPMS? If it's direct, after inflating the tires, it doesn't update the tire pressure immediately; it only shows the new pressure data after driving for a while, which seems a bit like the characteristics of ABS estimation. If it's indirect, it can still independently display the pressure of each tire, and the manual also mentions that the tire pressure display might be affected by wireless interference, which sounds more like the working principle of in-tire pressure sensors. So, I'm not quite sure why this TPMS needs to activate at speeds above 25 km/h.
