When the car starts, the ESP warning and engine fault warning appear, and it can't shift gears. It needs to warm up for half an hour before it can move. How can I solve this?
What are the issues when the warning lights for these fault codes appear on a 2015 MG GT?
My car failed to start twice, and various fault codes appeared. The diagnosis showed that the ambient light fuse was blown. Have you guys experienced this? How did you solve it?
My Scirocco feels jerky when shifting in S mode. At half throttle, it reaches 4000 RPM and reports an engine fault that needs repair. The EPC light is on, and it mentions something about oil pressure and the engine's maximum speed at 4000 RPM. What's going on, experts? Once I restart the car, everything seems fine (after the car is warmed up, with both water and oil temperatures up to normal levels).
4Gear shifting issue: When the car is cold and I switch from reverse to drive, it rolls back a bit after releasing the brake before moving forward. This doesn't happen when the car is warm. Anyone else experiencing this? It's a 2019 model with 80,000 kilometers on it.
5The engine warning light is on, and the idle seems unstable. The speed can still go up, but it doesn't accelerate as quickly as before. Could it be a problem with the throttle? Any insights?
6The dashboard reported low transmission performance, and then the car wouldn't accelerate. After restarting, the warning light went off and it drove normally. What could be the reason? (The onboard computer cleared the fault light, but it came back on before I got home.)
7Is it normal for the left side of the hood on the 2019 HS 2.0 Super Edition to be hot after parking? After about half an hour, it cools down and the whole hood is warm, but the temperature is acceptable.
8This morning, when I started my car, it showed a fault: "Electronic shift backup activated." What does this mean? Can anyone help explain?
9I drove for about an hour at night, and the battery warning light came on. Then I stopped driving. The next day, when I drove again, the warning light was off. Can you tell me what's going on and if it's serious? Thanks.
10Today gave me a scare! The light was green and suddenly a fault code appeared, and the car wouldn't move! Not sure what happened. I didn't have time to take a photo.
