عماد عبد العزيز
2022-11-18 11:19
When starting the Kaiyi X3 2021 model 1.5T automatic, the RPM can reach up to 1,450. Occasionally, it only reaches 700 or 800 RPM. Do other cars have this situation as well?
Comments( 6 )
فهد تكريتي
فهد تكريتي2023-01-10 22:08
Garbage trucks work like this.
عمر رأس
عمر رأس2023-01-04 12:22
When you start a cold car, the RPM is high because the engine needs to warm up and get lubricated. Once the temperature rises and everything is lubricated, the RPM naturally goes down.
عمر ميمون
عمر ميمون2022-12-24 10:02
I also have that kind of issue, but I didn't notice it in winter. It only happens in summer.
عبدالرحمن رومي
عبدالرحمن رومي2022-11-26 22:13
I have the same issue. In winter, sometimes the idle speed is very low right after starting, and other times it goes high. In summer, it's always 1500 RPM right after starting.
عماد عبد العزيز
عماد عبد العزيز2022-11-19 20:06
The content you wrote is clear. The key is what causes low RPM in certain situations and what impact it has on the car.
سلمان نادر
سلمان نادر2022-11-19 11:07
At startup, the engine revs high because the car needs to warm up and the oil needs to lubricate. Low revs might cause it to stall. Once the engine is properly lubricated, the revs will naturally drop.
My car's rear wiper starts moving by itself in the morning when I start the engine, even though the switch is off. It's happened three times. Fellow car owners, have you experienced this with your X3? It's a 2021 X3 1.5T automatic.
I have a 2021 2.0F1A manual Euro Victory, and when I shift from 2nd to 3rd to 4th gear and accelerate, there's a clicking sound between 1100 and 1400 RPM, like it's low on oil. Does anyone else experience this? Once the RPM reaches around 1500 and the turbo kicks in, the sound starts to decrease. The 4S shop upgraded the ECU, but the sound is still there, whether the AC is on or off.
The temperature is around minus three degrees, and suddenly today the gear shifting is very slow. It used to shift at around 2000 RPM, but today it goes up to 3000 RPM. The engine is making a humming noise. 😵‍💫 Do any other T-Cross owners experience this situation?
Is anyone selling a 2021 Kaiyi X3? I'm interested in buying one.
As a new driver, I've only driven the 2019 2.0 model, and I find the acceleration quite sluggish. When I press the gas pedal deeply, the engine needs to reach around 1800-2000 RPM to speed up a bit, and the engine noise is quite loud. Is this normal for a naturally aspirated engine with a CVT? I tried using the DS mode, which seems to provide what I consider normal acceleration, but I noticed the RPM goes up to four or five thousand. My friend's 1.5T Geely doesn't make much noise and feels more powerful.
I have a question for everyone. Occasionally, when opening the door of my 2021 Subaru Outback, the hazard lights flash a few times accompanied by a beeping sound, then it disappears. There's no indicator light on the dashboard, and there's no issue while driving. What could be the reason for this? I've been driving it for a few years and it's the first time I've encountered this situation.
It's normal for the idle speed to fluctuate when you turn on the air conditioning in a 2013 1.6 manual fashion model. Sometimes the RPM might go up to around 900 or almost 1000, and other times it might be around 800. If you restart the engine and the RPM goes back to around 800, it's usually not a cause for concern.
My Zhilong 2022 model 2.0 has reached 20,000 kilometers. When the engine is cold-started, there's a "dang dang dang" sound at 1500 RPM, but it's gone at 800 RPM. Is it the same for you guys?
Hello everyone, when driving an automatic Nissan Sunny, what's the situation when I brake and then accelerate, the RPM goes high but the car doesn't move? This often happens when turning as well, the RPM is high but it just doesn't go.
