حسن تاج الدين
2022-10-14 19:21
What causes difficulty in shifting gears in a manual transmission? Has anyone experienced this?
عمر ثابت
عمر ثابت2022-10-16 23:06
Clutch fully depressed point.
Is your 2018 manual KIA Pegas with 70,000 km experiencing difficulty in shifting gears, often failing to engage and grinding? It seems like the clutch isn't fully disengaging. Could this be a clutch issue or a problem with the gear linkage? How can it be resolved?
Has anyone experienced the transmission not shifting while driving the 2.0T model? Thank you.
I have a 2014 Haima S5 manual transmission, and it's not running smoothly. During acceleration, it feels jerky and there's a noticeable lag when shifting gears. What's causing this issue? Can any experienced drivers or mechanics help me out? 🙏🙏🙏🙏🙏
Has anyone experienced any abnormal noise when shifting gears with the 1.4T transmission? It's only at 28,000 kilometers.
Has anyone experienced gear shift jerking after just replacing the spark plugs and cleaning the throttle? It was fine for two or three days, but then the jerking returned.
What could be the issue with the 2019 JETOUR X70 having difficulty shifting gears? The clutch master cylinder and transmission have already been replaced, and the issue has somewhat improved. However, sometimes it's still hard to engage first gear.
Before driving, I can only shift gears by pressing the shift lock button, and once I shift back to the P gear, I have to press the lock button again to shift! The brake lights are working fine! I recently replaced the handbrake cable and gear cable. Has anyone else experienced this situation?
My Tianyu SX4 is a manual transmission, and the gear shifting feels a bit heavy. How can I fix this?
What could cause a loud banging sound when I shift gears after the car has been parked overnight?
