خالد مبارك
خالد مبارك
Nov 2
My car's rear wiper starts moving by itself in the morning when I start the engine, even though the switch is off. It's happened three times. Fellow car owners, have you experienced this with your X3? It's a 2021 X3 1.5T automatic.
Comments( 7 )
عبد العزيز عاطف
عبد العزيز عاطف2024-06-16 08:25
I have the same issue. Occasionally, it might not start when I try to ignite, and I feel like most of the time it's me doing something wrong.
فهد صارم
فهد صارم2024-03-10 15:24
Is it fixed now? As soon as it starts moving, the rear wiper activates too. Sometimes it even stops in the middle and doesn't return to its position.
خالد أكرم
خالد أكرم2023-12-12 23:02
I'm also [I want to be alone].
نايف حسين
نايف حسين2022-07-23 06:58
Have you ever had this problem before?
حسين موسى
حسين موسى2022-07-19 20:29
Me too.
حسن أبو بكر
حسن أبو بكر2021-11-02 19:20
Reset. Last time it was turned off without resetting, occasionally found this issue.
خالد بوتفليقة
خالد بوتفليقة2021-11-02 17:07
No.
When starting the Kaiyi X3 2021 model 1.5T automatic, the RPM can reach up to 1,450. Occasionally, it only reaches 700 or 800 RPM. Do other cars have this situation as well?
My 2021 Kia Pegas has a problem when I start driving on the highway—the tire pressure warning light comes on. But when I press the reset, it goes off. This happens every time I drive on the highway. Do any fellow drivers have the same issue?
Gear shifting issue: When the car is cold and I switch from reverse to drive, it rolls back a bit after releasing the brake before moving forward. This doesn't happen when the car is warm. Anyone else experiencing this? It's a 2019 model with 80,000 kilometers on it.
Hey fellow car enthusiasts, my Sportage suddenly started beeping and wouldn't start, no idea what I touched. It seemed like closing the hood fixed it. Has anyone else experienced this? It's happened to me two or three times in the past couple of months. Does anyone know how to solve this?
The "circle A" symbol for the start-stop system on the 2021 GV80's dashboard is flashing continuously, and the RPM won't go above 2500. Pressing the start-stop switch doesn't make any difference. Can anyone help explain what's going on?
My 2018 Mitsubishi ASX suddenly has an issue with the multifunction buttons on the steering wheel. When I press the next track button, it switches to the previous track. Pressing the previous track button takes me to navigation or the radio. I replaced the Android head unit three weeks ago, and everything was working fine after the replacement. The issue just started today. I'm not sure if it has anything to do with the new head unit. Does anyone know how to fix this?
Has anyone experienced the fast charging port opening by itself after parking and locking the car? I've noticed it happening three times already.
Hey buddies, does anyone have a rattling noise from the passenger side dashboard? My car is from 2021 and has less than 60,000 km. It happens when I turn on the power, while driving, and sometimes even when it's off. The noise also appears when I turn on the AC and occasionally when using the wipers.
I have a 2017 automatic model with 50,000 kilometers on it. Recently, I've noticed three particularly obvious issues: 1. When starting at traffic lights, even with light acceleration, I can hear the engine howling. The fuel consumption spikes to 19.9, the engine revs up to 2000 RPM, but the acceleration is very slow. 2. When driving home from work and going up the parking ramp, I often find that even with the gas pedal pressed, there's no power. The RPM goes up to 3000, and the fuel consumption also spikes. 3. Occasionally, when starting the car, it will shake and then stall by itself. Overall, driving at speeds between 0-40 is uncomfortable, but things improve above 60, especially on the highway. Acceleration and overtaking are fine at higher speeds. It's quite frustrating. Is anyone else experiencing the same issues?
Kaiyi X3
Kaiyi X3AED 48,000 ~ 50,000Petrol
