حسن غازي
2021-04-24 20:23
I want to ask, when driving this car above 120, the steering wheel shakes. Is it a wheel balancing issue, or is this just how the car is...
Comments( 10 )
عبدالله يونس
عبدالله يونس2022-07-27 21:31
I only start at 150.
محمد يحيى
محمد يحيى2022-07-25 00:40
The new car is very stable even at 140 km/h, but after driving it into a ditch once and getting it repaired, it feels like there's a slight issue.
محمد حارث
محمد حارث2021-10-23 21:54
I didn't find my 150.
علي بوتفليقة
علي بوتفليقة2021-05-01 10:54
If you repair or remove a tire, you need to do wheel balancing and alignment.
عبد العزيز خلوق
عبد العزيز خلوق2021-04-27 07:47
The top speed reached 193 once.
محمد أكرم
محمد أكرم2021-04-26 16:48
Perform a wheel balancing.
سلمان فاتح
سلمان فاتح2021-04-25 20:54
I've reached 140, and it didn't sway or shake at all. You should get an alignment and balancing done.
محمود حسين
محمود حسين2021-04-25 17:44
The resonance line stops shaking after 126.
عبدالله نعمان
عبدالله نعمان2021-04-25 14:32
I can drive up to 130 without any issues 😁
نايف إبراهيم
نايف إبراهيم2021-04-24 23:20
Go to the tire shop to get a wheel balancing.
Has anyone experienced the issue of the steering wheel shaking at speeds between 105-120 with the Iveco Daily, and if so, do you have any viable solutions?
Is it normal for the steering wheel to shake when driving at 120 km/h on the highway after the car has been driven for 100,000 kilometers?
What could be causing the steering wheel of my 2009 Lancer Sport to shake left and right while driving normally?
Iveco Ousheng, the new car was registered on June 1st. When driving above 110 km/h, the steering wheel starts to shake. Is it serious?
I have a 2015 Kia Sportage. The steering wheel starts to shake when I go over 120 km/h. What's going on? Can anyone help?
I bought a 2021 Changan Yuxiang from LinkCloud some time ago. There are just a few minor issues: 1. The car shakes and has a strong jerky feeling around 40 km/h, and it still shakes at speeds above 80 km/h. 2. When refueling, the fuel gauge fluctuates, but upon checking, there's no problem. I want to ask if anyone else has experienced this situation. 🙏
Hey friends, when the car is running, it shakes. I did a front wheel balancing, but it still feels a bit shaky. What could be the reason?
When driving on the highway, if the steering wheel starts vibrating when you exceed 100 km/h and the vibration becomes more pronounced at 120 km/h, it could indicate a few potential issues. It might be related to wheel balancing, alignment, or tire issues. You might want to have these checked by a professional to ensure safety.
On the day of the Mid-Autumn Festival, the reverse camera and 360 stopped working. I went to the 4S shop the next day for recalibration to fix it. Because the steering wheel was vibrating while driving on the highway, I did a wheel balancing and four-wheel alignment. Today, while driving on the highway, I noticed that the speed range at which the steering wheel vibrates has expanded, and now the seat also vibrates above 124 km/h. Can any expert provide some guidance?
When my car reaches a speed of 110, the steering wheel starts to shake. What's going on with that?
