I reset the central control screen to factory settings. Now, the keyless entry can only lock but not unlock. How do I set it up? There is power! It seems to be protected. How do I unlock the system?
How do I turn on the headlights when unlocking the vehicle at night? The headlight switch is set to the auto position.
How do I set up the compass on the 2014 navigation model? I can't find the setting option. I switched to a big screen 360. Could the change in the central control be causing the compass to malfunction? Please let me know how to set it up.
4How do I set the C30 to Chinese? I can't figure out the central control.
5My 2008 model's central control display screen switches from Bluetooth to the radio, how can I fix it? Also, what is the password for resetting the display screen to factory settings?
6Does the central control screen support original car settings?
7The keyless entry function on the GS 5 is not working properly. Approaching the vehicle no longer locks or unlocks it, and the function is unresponsive. The key fob's battery was just replaced. What's going on here?
8The car won't lock with keyless entry, and there's a beeping sound. How can I fix this? It unlocks fine, but there's a beep when trying to lock.
9After the central control was reset to factory settings, it shows that it can't connect to the network and can't enter the system.
10How do I turn off this central control screen? Looking for expert advice. 😭
