فهد مأمون
2022-08-18 20:28
I recently found out about this car and really like it, but the dealership in my area doesn't have it anymore. They said it's been discontinued and replaced by the Haval Jolion. I'm not sure if it's really no longer available.
عبدالرحمن رومي
عبدالرحمن رومي2022-08-22 14:05
Last year it was still there, not sure about today.
سلمان نادر
سلمان نادر2022-08-18 22:01
It's already discontinued, just not officially announced yet.
The engine number for the 2008 2.5T Volvo C70 is typically located on the engine block. It's usually found on the passenger side of the engine, near where the engine and transmission meet. You might need a flashlight to see it clearly, as it can be a bit hidden. Make sure to check around the area thoroughly.
I've been considering getting a Haval H7 recently, but I've seen a lot of negative reviews online. I'm not sure if these are genuine feedback or just haters. Is this car really a gas guzzler? What kind of fuel consumption can I expect in the city?
The 2022 Haval H9 is approaching 40,000 kilometers, and I'm not sure how much longer the original spark plugs will last. Fellow car enthusiasts, at how many kilometers did you change your spark plugs? What condition were the spark plugs when you replaced them? Thanks! ***** Also, I've clearly stated it's the Haval H9 and posted this in the Haval H9 section. Please make sure it stays within the Haval H9 circle and not other H9 circles. It's really tiring, you're quite something! *****
Has anyone experienced oil leaks? My car has only 9,000 kilometers, and during maintenance, they found the valve cover was leaking. It took a week, but I finally got it back from the dealership today 😂. I asked some fellow car owners, and it seems there's a certain chance of this issue occurring 😂. It feels like Subaru's quality control is really lacking!
I bought a 2017 V40 and recently the engine sounds like a tractor when running. Does anyone know what might be going on? The repair shop said it might be a cylinder scoring issue, but they're not sure.
Hello everyone! I bought a Jeep Compass in 2017. The dealership initially said this car requires 95 octane fuel, and I've been using it since 2017. However, when I drive, there's a jerking sensation when I decelerate and then accelerate again. Also, when I turn on the air conditioning, the engine noise becomes particularly loud. My car has less than 30,000 kilometers and I mainly use it for commuting. Recently, I tried using 92 octane fuel, but I found that the power was insufficient. When I tried to overtake, the car wouldn't accelerate, unlike when using 95 octane. So, I'm wondering, what fuel do you all use? Which type is better for the car?
Yesterday, I went to the dealership to check the air conditioning pressure. It was at 16 psi and the temperature was 7.6 degrees, and they said everything was fine. But by noon, it wasn't cooling anymore. 🤦‍♂️
How to fix the long brake travel on a 2014 Santana? The brake pads are thick, the rear drum brakes have been tightened, and the brake fluid has been changed. Recently, the brake travel has become longer, and I'm not used to it at all. When I press the brake, it feels like there's a hissing sound under my foot. Several mechanics said they can't adjust it. Any suggestions on which part needs to be replaced? Thanks!
