عبدالله سامر
2023-04-23 19:32
Has anyone replaced the central control system on cars after August 2019? If you removed the original system, did it trigger an engine fault code? How did you resolve it?
Hi everyone, when replacing the original navigation system of a Chinese-spec 93 with a used one, the speedometer isn't working. What could be the issue with the fault code?
Does the HiPhi X central control screen have an English system?
My car failed to start twice, and various fault codes appeared. The diagnosis showed that the ambient light fuse was blown. Have you guys experienced this? How did you solve it?
Is there anyone with a 2020 GA8 experiencing occasional engine shaking and exhaust fault codes? How did you solve the problem?
For the 2017 model, if the central control air conditioning vent is weak and you hear a loud noise from the air conditioning even when it's on maximum, but there's not much airflow, how can this be resolved?
Does the central control screen support original car settings?
I want to ask if any of you have noise issues with the central control? How did you solve it?
Is there any modification available for the central control and air conditioning knobs? The original ones don't look good.
Guys, can you help me figure out what I need to replace here? It's giving me a headache!!! "Jeep Liberty reports C121C Torque Request Signal Denied, first issue." "Crankshaft/Camshaft Timing Misalignment - Bank 1 Sensor 1 - Powertrain Control Module (PCM) fault code: P0016, this is the second issue." "Camshaft Position Sensor Circuit - Bank 1 Sensor 2 - Powertrain Control Module (PCM) fault code: P0365, this is the third issue." "Camshaft Position Sensor Intermittent - Bank 1 Sensor 2 - Powertrain Control Module (PCM) fault code: P0369." "Bank 1 Camshaft 2 Position Slow Response - Powertrain Control Module (PCM) fault code: P000B." "Torque Request Signal Denied - Anti-lock Braking System (ABS) fault code: C121C."
