سلمان فرج
2022-01-16 17:59
Does your engine shake after the first maintenance? Mine is shaking quite a bit after today's first maintenance, and the engine noise is louder than before!
محمد يحيى
محمد يحيى2022-07-24 23:36
I just got the oil, oil filter, and air filter changed on my car. How much can it really shake after that?
عبدالرحمن حكم
عبدالرحمن حكم2022-02-09 21:03
It still shakes a lot, and the noise is loud.
Has anyone experienced the engine warning light flashing and the vehicle shaking? It gets better after a while.
Has anyone noticed increased noise after the first maintenance?
What's the fuel consumption for your 2.4 NA engine? Mine is around 14, is that normal? It feels a bit high.
I have a 2009 Touran 2.0 manual, and I'm having trouble shifting into first and reverse. Is anyone else experiencing this? Also, when I release the clutch in first gear, the engine shakes like it's about to stall. It also shakes a bit during rapid acceleration. Is this normal?
Hello MDX car owners, how many liters of engine oil do you usually add during maintenance? How many kilometers can you run? I used Mobil this year, added 5 liters each time, but the oil is almost running out after just over 5000 kilometers. It's burning quite a bit, is this normal?
Today, after starting the car, the engine vibrates quite severely, but after a while, it gets better. Does anyone know what the reason might be?
How many kilometers before the first maintenance for a Land Rover Defender?
I have a 2012 Subaru Outback with an EJ25 engine, almost 200,000 kilometers. It has noticeable shaking at idle and stalls during sudden braking, especially when the engine is cold. I cleaned the throttle body carbon build-up recently, which improved it a bit but didn’t completely solve the problem. The engine is quite loud during hard acceleration, and I’m not sure if it’s the engine or the transmission. Also, recently it shakes at speeds over 100 km/h. Anyone experiencing the same issues?
Has your engine fuel line been replaced? Mine gave a warning today and needs to be replaced.
Does your 1.6 naturally aspirated engine consume oil too? Mine has only run about 90,000 kilometers, and after the last maintenance, I drove less than 2,000 kilometers before the oil light came on. When I checked the oil dipstick, it couldn't even reach the oil level.
