Dear fellow car enthusiasts, my Kaiyi X3's dashboard is showing a yellow triangle with an exclamation mark inside. Has anyone encountered this? What might be the issue?
The dashboard shows a headlight malfunction. How can I fix this? Has anyone encountered this before? Please advise.
4Hey fellow car enthusiasts, I've heard that the T8's engine noise inside the car is quite loud when it's running. How bad is it, and is it tolerable?
5Fellow Territory S owners, have you experienced a situation where the dashboard shows a message saying the transmission needs maintenance, and when you accelerate, the RPM increases but there's no power?
6Fellow car enthusiasts, my GS5's central control screen keeps rebooting. The 4S shop said the main unit is broken and it would cost 6k to replace it. [Facepalm] Has anyone else encountered the same issue? Is it possible to repair it?
7What does it mean when a yellow exclamation mark appears next to the start-stop light on the dashboard after sudden braking?
8The dashboard shows that the electronic key is not inside the car, but the key is inside. How to solve this issue?
9I've checked the high and low beam lights outside the car, and they can be turned on and off normally. However, when I switch to the high beams, the dashboard keeps showing a "high beam fault," whereas there is no fault reported for the low beams. Can any experts advise on what exactly might be the problem?
10The issue with the cruise control not holding could be due to several reasons. While the indicator light on the dashboard shows that the cruise control is activated, it might not maintain the set speed.
