عمر طل
2022-07-04 12:28
Can a loudspeaker be installed on the A-pillar of the 2019 Cowin X3?
Comments( 7 )
عبدالرحمن عزيز
عبدالرحمن عزيز2022-09-06 16:15
It's easy to run the wiring directly under the dashboard. I spent 10,000 upgrading my sound system.
عبدالرحمن حكم
عبدالرحمن حكم2022-07-14 20:52
You can buy a set of two-way speakers and run the wiring through the car door.
عبد لطيف حسين
عبد لطيف حسين2022-07-12 12:23
Beijing ❌3 is possible.
لطيف عبد العزيز
لطيف عبد العزيز2022-07-12 06:41
You can directly connect it to the large screen.
حسن زين
حسن زين2022-07-10 00:00
Go check out my upgraded loudspeaker system.
حسن زين
حسن زين2022-07-09 23:59
It can be modified.
عبدالله سامر
عبدالله سامر2022-07-08 08:33
It can be installed, but there's no wiring harness. You'll have to remove a lot of covers, which is quite troublesome.
