When in D gear, the front parking radar starts beeping continuously even when the distance to another car is about 10 meters. Pressing the OK button stops the beeping, but it starts again when you shift back to D gear, repeating the cycle.
Have you ever encountered a situation where the car doesn't move in D gear, and you have to shift to 1st or 2nd gear to start moving?
Is it normal for the RPM to increase by 100-200 when shifting the FJ from D to N, and then continue to maintain the increased RPM?
Why does the Changan Yuexiang jerk when starting in D gear?
4Guys, I'm really freaking out. Just now, while driving smoothly, the D gear light (the one on the gear shift) started flashing, and the dashboard showed "Please shift to D gear first before selecting the appropriate gear." I was in a panic and didn't know whether to press the brake and shift to P gear or shift to P gear and then to D gear, and then it prompted "Speed too high to shift into D gear (or maybe P gear, I forgot)." It was terrifying, the car felt like it was in neutral and there was no power when I pressed the accelerator. I managed to park on the side using inertia, shifted back to P gear, and then to D gear, and it resumed normal driving. I want to ask you guys, what's going on here exactly? Is there a specific part that's malfunctioning?
5Why does the car beep three times when starting, like the sound when a door isn't closed properly?
6Has anyone experienced issues with the radar not working? I recently noticed that when I turn on the radar, it beeps three times, and then there are no distance alerts. Is it broken?
7Hey experts, when your car insurance expires, do you continue with Zhongcheng Insurance or choose another one?
8When you shift to D gear and press the accelerator to start, does your car make a buzzing sound, like exhaust resonance?
9I recently got a CX-5 less than a month ago, and I noticed that when starting the car cold and shifting to D gear, there's a noticeable "jerking" sensation as the car moves forward. After driving for a while and the car warms up, when switching between N and D gear, the jerking sensation is still there but much less noticeable. Is this normal?
10Why is there an impact when shifting from R to D gear?
