There's a bug in the fuel consumption mileage stats of the Nissan X-Trail EP, which causes it to reset automatically. This has happened a few times, and each time all the data on the "Since Last Refuel" page gets cleared. I'm not sure if it's a bug. It's still hard to pinpoint the exact conditions for the issue to reoccur, but I can confirm it should include the following: 1. Long periods of idling without turning off the engine 2. Unlocking the car doors 3. Leaving the car with the key (out of sensing range) Then, when you return, you'll find the data has reset. This has happened three times, and looking back, it was pretty much under these circumstances.
Hi everyone, sometimes my Mazda 2 sedan has a hard time starting, but it only happens occasionally. It struggles on the first attempt, but starts up easily on the second try. What could be the issue here?
My 2021 Kia Pegas has a problem when I start driving on the highway—the tire pressure warning light comes on. But when I press the reset, it goes off. This happens every time I drive on the highway. Do any fellow drivers have the same issue?
My 2019 Jeep 1.3T Renegade has over 73,000 kilometers. When I release the brake in reverse on a slope, there's a muffled "bang" sound with a sense of impact. It occasionally happens on flat ground too, but the sound is much quieter. Can anyone tell me what's going on here?
4Has anyone experienced the fast charging port opening by itself after parking and locking the car? I've noticed it happening three times already.
5My MG ZS often has the gear indicator light go off, and I can't shift it into the P gear. It's happened four or five times now. It's really frustrating, this car keeps needing repairs.
6Has anyone experienced idle speed being sometimes high and sometimes low? When I'm waiting at a traffic light, sometimes it's 7500, sometimes 9500, and this is without the AC on. The last two times, right after refueling, the idle speed was 9500. Not sure what's going on.
7It sounds like you're experiencing an issue with your 2012 Peugeot 308 not starting, and you're hearing a clicking sound with the onboard computer resetting. Since the battery has been tested and has power, the problem could be related to the starter motor or its connections, the ignition switch, or a potential issue with the car's electrical system, such as a bad ground or corroded terminals. It's recommended to have a professional mechanic check these components to diagnose the exact issue.
8In the past couple of months, I've experienced my car's system crashing twice. The first time, I had to disconnect the car battery and reset to factory settings to get it back to normal. But after about ten days, it happened again. This time, I didn't do anything, and after letting the car sit for an hour, it started working fine again. I'm not sure if it's a hardware or software issue, as I haven't updated the system for quite some time. Has anyone else experienced something similar?
9I've only driven my Sol 11 for 4500 kilometers, and the camera's view has been limited three times already. While it doesn't affect driving, it's pretty annoying. The car's infotainment system is really bad.
10There's a bug in the fuel consumption mileage stats of the Nissan X-Trail EP, which causes it to reset automatically. This has happened a few times, and each time all the data on the "Since Last Refuel" page gets cleared. I'm not sure if it's a bug. It's still hard to pinpoint the exact conditions for the issue to reoccur, but I can confirm it should include the following: 1. Long periods of idling without turning off the engine 2. Unlocking the car doors 3. Leaving the car with the key (out of sensing range) Then, when you return, you'll find the data has reset. This has happened three times, and looking back, it was pretty much under these circumstances.
