أحمد رأس
2024-05-10 07:42
The trunk door of my X-Trail can't be opened or closed manually (I can hear a click from the manual button, but the door doesn't pop up automatically). However, it can be opened with the key. What could be the issue? Please help, thank you 🙏
عمر مجدي
عمر مجدي2024-10-20 17:32
Bro, did you solve it?
علي عبد عزيز
علي عبد عزيز2024-05-18 12:10
If the car is not in park (P), the drive (D) gear may not be accessible.
قابوس عمر
قابوس عمر2024-05-17 07:48
Bro, how did you finally open it? I'm facing the same issue.
Where is the button to open the trunk if it won't open?
The FJ keeps showing that the door is not closed. Pressing the lock button makes it beep continuously. Manually locking it works, but it still shows that the door is not closed.
Hi everyone, I need some advice. The middle doors on my T6 keep having issues. Sometimes they automatically open or close halfway and then suddenly bounce back. Other times the button doesn't work at all, and the door button flashes a fault. Sometimes I have to press the button twice, holding it down on the second press until the door fully opens or closes before I can release it. What could be the problem, and how should I fix it? Please help.
Hey guys, does anyone know why the trunk can be opened with the key but not by pressing the button?
Is there no interior trunk release button on the 2016 Red Badge 1.5T Automatic 2WD Luxury model? Can it only be opened from the trunk door? Anyone who knows, please help 🙏
Hey car enthusiasts, have you ever experienced the trunk opening when you press the car key to unlock or lock the car? The sensor works fine for opening and locking the doors! But when I use the key to press the trunk button, it opens. What's going on??
2014 Peugeot 2008 manual transmission, the remote key can't unlock the driver's door (can open with the key), while the other three doors work fine. Any advice on how to solve this issue? 🙏🙏🙏
My car's trunk won't open electrically; I have to use force to open it manually.
Could someone please tell me how to open the trunk of the 2014 Nissan X-Trail Comfort version? I couldn't find the trunk button.
Nissan Nissan XTrail
Nissan XTrailAED 84,900 ~ 148,000Gasoline & Petrol
