سعود مساعد
Oct 25
No matter how you put it, it's still a three-cylinder engine.
Does your engine cylinder head leak oil?
How can you tell if an engine has overheated and suffered from cylinder scuffing?
Can you still buy a three-door version of the Pajero?
4How is the 2024 hybrid Sylphy with a three-cylinder engine?
5If you're deciding between the MG ZS and MG HS in Europe, here are some considerations: MG ZS comes with a 1.0T engine and a 6-speed automatic transmission. However, it's a three-cylinder engine. On the other hand, the MG HS features a 1.5T engine with a dry dual-clutch transmission and is a four-cylinder. There are reports online that the MG HS might experience significant jerking issues after a year or two due to the dry dual-clutch transmission. You might want to weigh the pros and cons of each engine and transmission type based on your driving preferences and needs.
6Will there still be Jeep Liberty available in three years? I'm planning to buy a used one to drive in three years.
7Is there a twelve-cylinder engine available?
8What do you think about the three-cylinder Nissan X-Trail? Please share your thoughts.
9Hey everyone, how many kilometers before you need to change the fuel filter? Does it matter if I don't use the original one?
10Is the 2023 Nissan X-Trail equipped with a three-cylinder or four-cylinder engine?
