حسين كمال
2024-09-27 22:16
Is the Nissan X-Trail EP using a direct or indirect TPMS? If it's direct, after inflating the tires, it doesn't update the tire pressure immediately; it only shows the new pressure data after driving for a while, which seems a bit like the characteristics of ABS estimation. If it's indirect, it can still independently display the pressure of each tire, and the manual also mentions that the tire pressure display might be affected by wireless interference, which sounds more like the working principle of in-tire pressure sensors. So, I'm not quite sure why this TPMS needs to activate at speeds above 25 km/h.
عبدالله فخر دين
عبدالله فخر دين2024-09-29 19:45
So far, all the cars I've driven with tire pressure monitoring require driving a certain distance before the tire pressure is displayed. This includes the new Mercedes S-Class, Toyota Vellfire, and Tesla Model X.
حسين كمال
حسين كمال2024-09-28 20:16
Also, I don't quite understand why this part uses a rubber valve instead of an aluminum alloy one. It ages easily.
حسين صارم
حسين صارم2024-09-28 20:09
When I inflate the tires, the pressure will show up, but it takes a while. Previously, when the front tire reached 2.2, I would wait for the car to cool down before inflating again (using my portable pump connected to the trunk battery). At first, it doesn't show, but after a while of inflating, it does.
عبدالله أسماء
عبدالله أسماء2024-09-28 00:26
Direct sensor without built-in electromagnetic coil.
حسن شادي
حسن شادي2024-09-27 23:34
To save power, the sensors only work when the car is in motion.
How to reset the tire pressure on an F150 after patching the tire? [what][what]
How to reset the tire pressure display?
Which tire pressure monitoring system did the master use? Can you share a link?
Does Cetus Luxury have a tire pressure display?
How do I reset the tire pressure after a repair? It still shows low pressure on the right rear tire.
After replacing the full-size spare tire on a Robin Hood, will the tire pressure monitoring system still function properly?
How can I change the display on the left side of the dashboard screen? Mine always shows a car model, but I've seen others display tire pressure.
Today, I inflated the tire and reset the tire pressure, but it's still showing "monitoring" even after driving up to 25 km/h. I took it for a spin, but it didn't help.
Why do my Ariya tires need to be inflated every week? All four tires are losing air. I inflated them to 270 kPa, but after a week, they're only at 250-260 kPa.
Nissan Nissan XTrail
Nissan XTrailAED 84,900 ~ 148,000Gasoline & Petrol
