Is the 0W-20 Shell Helix Ultra suitable for my 2019 Nissan X-Trail 2.0? It has nearly 90,000 km on it, and I've just changed the three filters, transmission fluid, and brake fluid. Also, my friends say I should replace the timing belt and spark plugs. Is that true? Any brand or model recommendations?
Do I need to change the timing belt at nearly 90,000 kilometers?
Should I choose the Haval or bite the bullet and go for the Explorer? I'm 40, work in a stable job, don't smoke or drink, and love driving. Whenever I go out with friends, I'm the one driving, and I enjoy it even if it's a five or six-hour drive. I don't feel tired. I usually commute alone, about 20 kilometers round trip. Rationally, I should prioritize family and choose the Haval. It's not much fun to drive, but it's cheaper and comfortable for the family. But there's a little devil on my shoulder saying: Go for the Explorer, there aren't many days left to indulge in what you love. Most of the time, you're driving alone, so why not get something you truly enjoy? You only go on trips a few times a year. Brothers, any advice?
4Is it necessary to replace the belt for my Vitara, which has almost 90,000 kilometers on it?
5My Taurus just hit 30,000 kilometers. What maintenance does it need? Do I need to change the spark plugs and brake fluid? Thanks, everyone!
