Is it common for a 2016 Nissan X-Trail with 120,000 km to have the air conditioning leaking refrigerant after two long trips, with a two-month interval? Is it an issue with the compressor or the evaporator leaking?
The air conditioning isn't cooling. I checked the pipes and found no leaks. However, after adding refrigerant, it was gone in less than two months. For an 11-year-old imported Mazda CX-7, what usually causes this issue?
What do you think about the three-cylinder Nissan X-Trail? Please share your thoughts.
What is the fuel consumption of the Nissan X-Trail e-Power for the first time?
4Which one is better, the Nissan X-Trail e-Power or the Mazda CX-50?
5Is it normal for the brake pedal of the Nissan X-Trail Classic to make a loud noise when it rebounds and contacts the brake light switch?
6Is the 2023 Nissan X-Trail equipped with a three-cylinder or four-cylinder engine?
7Can owners of the 2021 Nissan X-Trail play video songs while driving?
8The 2020 Nissan X-Trail sometimes has a start-stop malfunction when starting the car. What could be the reason for this?!!!
9Is it common for a 2016 Nissan X-Trail with 120,000 km to have the air conditioning leaking refrigerant after two long trips, with a two-month interval? Is it an issue with the compressor or the evaporator leaking?
10I've had the Nissan X-Trail Hybrid for just half a month and took it on a long trip, about 3000 kilometers. Everything else is fine, but once the dual-zone climate control is turned on, it can't be turned off. Also, when the engine starts, there's a loud noise like an electric drill. Do any other owners have the same issues?
