I picked up my Nissan X-Trail Classic in March '24. While driving, I always feel the brake pedal makes a loud noise when it rebounds, especially when I release the pedal quickly.
Does anyone feel that the 1.6T accelerator is a bit unresponsive, especially when overtaking or accelerating quickly?
I have a 2013 manual Nissan March, and it feels like driving a tractor with a loud engine noise. What could be the issue?
Do I need to modify anything for the wiring when swapping a 1.8 engine into a Classic Fengfan 1.5, or is it a straightforward swap?
4Why is it indicating that I need to change the oil again when I just changed it in March?
5Does the Nissan X-Trail Classic have a leakage issue? Should I cut off the sunroof drain hole insect screen in advance? Should I use underbody armor spray?
6I picked up my Nissan X-Trail Classic in March '24. While driving, I always feel the brake pedal makes a loud noise when it rebounds, especially when I release the pedal quickly.
7Is it normal for the brake pedal of the Nissan X-Trail Classic to make a loud noise when it rebounds and contacts the brake light switch?
8Today, while driving my 2020 automatic Chery Arrizo 5, I heard a squeaky noise from the accelerator pedal when I pressed it to accelerate. When I released the pedal, it didn't return to its original position and kept accelerating, which scared me, so I quickly braked and pulled over to turn off the engine. I then shifted to neutral and started the engine, which roared to over 4000 RPM. After turning it off, I manually adjusted the pedal, heard the squeak again, and then it started working normally. Occasionally, there's still a noise when pressing the accelerator, but the pedal returns to normal. Does anyone know what might be causing this issue or what might be broken?
9The 2020 Nissan X-Trail sometimes has a start-stop malfunction when starting the car. What could be the reason for this?!!!
10Could someone please tell me how to open the trunk of the 2014 Nissan X-Trail Comfort version? I couldn't find the trunk button.
