Hi everyone, I need some advice. I have a 2016 Nissan X-Trail with 70,000 km on it. The AC blows cold air for about 10 minutes, but then the airflow decreases. If I turn off the AC for a while and then turn it back on, it works fine again, but after a few minutes, the airflow decreases once more. Alternatively, if I turn off the AC, the airflow increases, and when I turn the AC back on, it runs normally, but after about 10 minutes, the issue returns. What could be the problem? Thanks!
Hey everyone, my 2011 Accent sometimes won't start after parking, but if I wait for about 10 or 20 minutes, it starts up again. What's going on?
Hey guys, why does the AC sometimes turn on by itself after starting the car? I usually don't forget to turn it off.
After your ASX is turned off, can you hear a clicking sound from the air conditioning vents on the dashboard after about a minute?
4I bought a 2023 Lavida Star Edition in July. Last week, I accidentally noticed a strange noise around the right rear tire about six minutes after turning off the engine. Friends, do you know what might be causing this?
5Hello fellow car enthusiasts, I have a 2013 VW Jetta manual comfort model. After running the AC for about an hour, the airflow becomes weak and almost stops. If I pull over, turn off the AC for a while, it goes back to normal. Has anyone else experienced this issue?
6Is your 2021 GAC GS4 Tech Edition still powering the screen after the engine is turned off, taking about two minutes to cut the power? Has this change happened to you as well?
7Hello everyone, when I start my car cold, it makes a "dada" sound and the RPM goes up to over 1000, but it goes back to normal after about a minute. Is this normal?
8When I turn on the air conditioning, the cooling fan starts spinning, then stops after a while. The cycle of spinning and stopping is roughly one minute. Even after turning off the car, the fan keeps running and won't stop. Only by restarting the car and then turning it off again does the fan stop. Could the temperature sensor be malfunctioning? Any insights from the experts?
9When the air conditioning is turned on in the 3008, it triggers an alarm, but it goes back to normal when the AC is turned off. What could be the problem and how can it be resolved?
10Hi everyone, I need some advice. I have a 2016 Nissan X-Trail with 70,000 km on it. The AC blows cold air for about 10 minutes, but then the airflow decreases. If I turn off the AC for a while and then turn it back on, it works fine again, but after a few minutes, the airflow decreases once more. Alternatively, if I turn off the AC, the airflow increases, and when I turn the AC back on, it runs normally, but after about 10 minutes, the issue returns. What could be the problem? Thanks!
