عبدالرحمن إدريسي
2024-11-21 17:38
Has anyone experienced this kind of clanking noise that occurs occasionally? What could be the issue?
عمر زيد دين
عمر زيد دين2024-11-22 04:35
How many kilometers has it run?
Has anyone experienced the driver's door window on the Scirocco only lowering a little bit when opening the door? What could be causing this issue?
When turning on the air conditioning in my 2006 Previa ACR50, I occasionally hear this sound. Can any experts help explain what's happening? Has anyone experienced a similar issue, and what could be the cause? It's a 2.4.
Is there a clunking noise from the front left when driving on bumpy roads? Has anyone experienced this issue?
Is there a rattling noise from the chassis when accelerating with the H7? Has anyone experienced the same issue?
When driving at low speeds and turning the steering wheel, the 2014 XV experiences significant body vibration and loud noise. However, this issue does not occur when the car is cold and has just started. I want to know what the reason could be? Does anyone else have the same situation?
Have you ever experienced occasional jerking with the 2.4 transmission? What could be the issue?
Is there anyone who has experienced an occasional rattling noise while driving? It seems to be coming from the left rear door lock area, making a "da da da" sound.
Has anyone experienced a problem with the MINI head-up display not rising? What could be the reason?
This morning while driving, there was a sudden jolt as if the car was about to stall, but then it was fine. Has anyone experienced this? What could be the issue?
Anyone else experiencing occasional rattling noises from the 24 model's dashboard? It sometimes goes "dang dang dang," but when I take it to the dealership, the noise disappears and they can't find the issue.
Nissan Nissan XTrail
Nissan XTrailAED 84,900 ~ 148,000Gasoline & Petrol
