Does the transmission fluid of the X-Trail really need to be changed? I've heard from people around me that you should drive the car until it's scrapped, and that goes for any car's transmission fluid. They say just change the engine oil every 10,000 kilometers. Is that right? Can someone who knows explain?
Where is a good place to get the transmission fluid changed on a 2010 MDX? Thanks 🙏
Can the original engine oil of the 90 Zilong Edition last for 10,000 km before needing a change? Changing it every 5,000 km seems too frequent.
4How often should the transmission fluid be changed? It's been almost two and a half years, and I've driven nearly 40,000 kilometers. The dealership suggests replacing it.
5How often should the transmission fluid be changed?
6How often should transmission fluid be changed?
7Is it necessary to change the transmission fluid for a 2010 Suzuki SX4 Hatchback 1.6 Automatic that has traveled 160,000 kilometers and hasn't had a transmission fluid change yet? The gear shifting is currently very smooth.
8Has anyone changed their transmission fluid? How many liters did you use? Did you do a gravity change or a full cycle change???
9How often should transmission fluid be changed? I bought my Outlander in July 2020, and it has been four years with only 10,000 kilometers driven. However, the dealership says it's time to change it due to the time elapsed, or else the warranty won't cover transmission issues. Has anyone here changed their transmission fluid? Did you use the mechanical circulation method or the gravity method? With just 10,000 kilometers, do I need to remove the oil pan for cleaning before changing?
10Hello everyone! Is it necessary to change brake fluid every 40,000 kilometers? How should I choose brake fluid? Which brand should I choose?
