عبد العزيز تميمي
2024-09-30 22:39
The inner button on the passenger door isn't working, but it can be opened using the screen controls and from the outside. What could be the reason for this?
عبدالرحمن هاماوي
عبدالرحمن هاماوي2024-10-02 14:04
The sensor might not be receiving a signal. Schedule a service appointment through the app to have it checked.
The side electric sliding door of the Multivan can open, but it doesn't respond when closing. What could be the reason?
In a 2019 manual vehicle, if the steering wheel buttons suddenly stop working and after resetting and reconfiguring, the buttons still don't respond, what could be the reason?
Hi everyone, I need some advice. The middle doors on my T6 keep having issues. Sometimes they automatically open or close halfway and then suddenly bounce back. Other times the button doesn't work at all, and the door button flashes a fault. Sometimes I have to press the button twice, holding it down on the second press until the door fully opens or closes before I can release it. What could be the problem, and how should I fix it? Please help.
What could be the reason that when I press the key, the car doesn't respond and the doors won't open?
The child lock on the right rear door of the 2014 V60 is not engaged, but the door cannot be opened from the inside, only from the outside. What could be the issue?
Why does the driver's door not open with the key unlock button after locking the car from the outside, while the other three doors can be opened?
My 2021 Outlander's trunk suddenly won't open (can be opened with the emergency button inside). The lock button on the driver's side isn't working properly, can't lock the car. Any experts know how to fix this?
How to set up the Ariel so that the front passenger or rear passengers can open the door without the driver needing to press the unlock button? Please help!
If the engine isn't turned off, can the doors not be opened from the outside? I'm new to this, and it was awkward twice today. 😅
Zeekr Zeekr X
Zeekr XAED 201,900Electric
