حسين حارثي
2023-08-13 13:25
Honestly, if they just change the interior and center console design of the Y, I'd be interested.
حسين بشير
حسين بشير2023-10-07 15:22
Wait for the facelift. I almost bought this car last year, but I decided to wait and see the facelift.
Regretting it now, the center console doesn't support Bluetooth. I have to download music onto a USB drive, it's like using an MP4 player. I even bought a Bluetooth adapter, but it still doesn't work. Can't read it at all. I'd really like to know who designed this. Did they really save that much by not including Bluetooth? Also, the noise while driving is quite loud. It's unbearable on long drives.
The differences between the 2018 XV and the 2020 XV are mainly in design, features, and technology. The 2020 model generally has updated styling, improved safety features, and possibly enhanced infotainment options compared to the 2018 model. Specific differences can include things like changes in engine performance, interior materials, or additional driver-assistance technologies.
When will this car drop below 100k? I was considering this one and the 5 Series, but ended up with the 5. However, the design of this car is just too stunning. If it goes below 100k, I wouldn't even care about after-sales service, I'd buy one just for the looks.
To replace the gear shift boot on a manual 2018 MG ZS, follow these general steps: 1. **Remove the Gear Knob**: Unscrew the gear knob by turning it counterclockwise. Some models may have a clip or screw that needs to be removed first. 2. **Detach the Center Console**: Depending on the design, you may need to remove screws or clips holding the center console in place. Carefully lift the console to access the boot. 3. **Remove the Old Boot**: The boot is usually attached to the console with clips or staples. Gently detach it without damaging the console. 4. **Install the New Boot**: Secure the new boot onto the console by attaching it with clips or screws, ensuring it fits snugly. 5. **Reattach the Center Console**: Place the console back and secure it with screws or clips. 6. **Reattach the Gear Knob**: Screw the gear knob back on by turning it clockwise. Make sure everything is securely fastened and test the gear shift to ensure smooth operation.
Hi, buddy! If you're trying to change the music in your Alphard and can't find where to plug in the USB, I totally get it. In the Toyota Alphard, the USB port is usually located in the center console or near the dashboard. Sometimes, it can be a bit hidden, so you might need to check around those areas carefully. Hope this helps!
Sure, here you go: 1. For the dash cam and Sentry Mode, can I get a larger SSD? I saw some videos where people used a 1TB SSD and it worked. 2. Is there a specific anti-insect screen for the Model X? Can the one used for the Model Y be used on the X? Should I buy it and bring it for installation during delivery? 3. Can the integrated charging hub used for the Model Y's center console be used on the Model X?
The Jeep 2500 has been gone for many years. Can't they just transfer the interior from the 212? Even if there are no designers, they could at least copy it, right? [Facepalm] I've always liked this car, but every time I'm about to change cars, the interior makes me reconsider.
I just got my G70. How did everyone install their dash cams? Did you run the wires through the A-pillar and then route them under the center console to connect to the cigarette lighter?
Is anyone aware if the Prado will be redesigned next year? I just hope for a larger fuel tank, less hard plastic in the interior, and some changes to the trunk. No other demands. [crying][crying][crying]
