Hey guys, how's the driver monitoring system (DMS) on the Hiphi X? Does it alert you when you're driving tired? Is it worth the money or just a gimmick?
Does the 2018 Subaru Legacy EyeSight Honor edition have a tire pressure monitoring system?
Does the HiPhi X central control screen have an English system?
4The tire pressure monitoring system suddenly gave an alert, but the tire pressure is normal. I drove 100 kilometers and it still hasn't reset. How can I fix this?
5Can the Ranzhi be equipped with a tire pressure monitoring system?
6Hey guys, does the 2017 Honda City have a tire pressure monitoring system? I can't find it. Can anyone reply? Thanks.
7How much is the HiPhi X worth now, and will its battery be replaced in the future with one that has a longer range?
8Which tire pressure monitoring system did the master use? Can you share a link?
9Hi everyone, how do I reset the tire pressure monitoring system on a 2021 RX5 Max after fixing a tire?
10After replacing the full-size spare tire on a Robin Hood, will the tire pressure monitoring system still function properly?
