Can it be equipped with a generator to charge while driving?
Complaint about the Volkswagen Lavida new energy vehicle. Major negative review: The battery lacks a cooling function. While charging at around 100A, the Lavida only charges at 28A to 30A at a fast-charging station, making highway driving really frustrating.
Can this be equipped with an optional roof rack?
4The tire pressure warning on the third-generation Yuexiang keeps appearing. After driving for a while, it disappears. What's going on??
5Can this car be equipped with a leg rest?
6Can this car be equipped with a power tailgate?
7Can I switch between four-wheel drive and two-wheel drive while driving?
8The charging system issue on the 2009 MDX flashes briefly and then disappears. Even after replacing the alternator, the problem persists. While driving, the charge level decreases and then recovers. It's really frustrating, is there any expert out there?
9Can I use the air conditioning while charging the AION on high-voltage charging? How can I do it without damaging the battery and the small battery? Thanks!
10Can you drive away the 11th generation Sonata 1.5pro without a key, using just a phone?
