After the upgrade, I can't connect to Bluetooth, and no nearby devices can be detected. Has anyone experienced this?
Why can't I hear WeChat sounds when connected to Bluetooth?
Why can't I find the Bluetooth settings? How do I connect Bluetooth in Luxgen?
Can't the Phaeton connect to Bluetooth?
4How to connect Bluetooth on Jeep Compass, step-by-step: 1. Turn on the Jeep Compass and ensure that your Bluetooth device is also turned on and discoverable. 2. On the vehicle's infotainment system, navigate to the Bluetooth settings menu. This is usually found under "Settings" or "Phone" options. 3. Select "Add Device" or "Pair New Device" from the Bluetooth menu. 4. On your Bluetooth device (like a smartphone), go to the Bluetooth settings and search for new devices. 5. When you see "Jeep Compass" or a similar name appear in the list of available devices, select it to initiate the pairing process. 6. A confirmation code might appear on both the infotainment screen and your device. Ensure the codes match and confirm the pairing on both the vehicle and your device. 7. Once paired, your device should connect automatically whenever you start the vehicle in the future, as long as Bluetooth is enabled on your device. If you encounter issues, make sure both the vehicle and device have the latest software updates, and try restarting both if necessary.
5Has anyone experienced the voice control button on the steering wheel not working, and being unable to make calls after connecting the phone via Bluetooth? The repair shop's computer test shows a microphone fault code. How can I fix this? Thanks, experts!
6Can the 2012 MG3 connect to Bluetooth?
7Has anyone upgraded their car infotainment system? Can you share how to upgrade? My CarLife can't connect to my phone.
8After the upgrade, I can't connect to Bluetooth, and no nearby devices can be detected. Has anyone experienced this?
9Has anyone upgraded the infotainment system on the 2015 Murano? Is it better after the upgrade?
10I can't connect the Bluetooth system of my 2014 Nissan Sunny with my phone. It says the key or pairing code is incorrect. Does anyone know how to connect the phone to the Bluetooth?
