خالد موسى
2024-06-19 08:47
Looking for advice on changing tire and wheel sizes. The original Sahara comes with 245/75/17 ET+44. Considering two options for new wheels and tires: Option A: 265/70/17 ET+18 9J, where the tire is flush with the fender. Option B: 265/70/17 ET 0 8.5J, where the tire slightly protrudes beyond the fender. Which option is better in terms of performance and safety?
خالد موسى
خالد موسى2024-07-04 13:58
Guys, I changed the zero value... Not much difference, the car feels a bit more stable, but the turning radius increased a bit, and the front feels a bit slower to respond, kind of like driving a bigger car.
خالد موسى
خالد موسى2024-06-21 11:04
Is there anyone who can take a look?
خالد موسى
خالد موسى2024-06-19 17:41
Can any expert help with this?
خالد موسى
خالد موسى2024-06-19 14:33
Sure, feel free to ask your question!
Where can I buy tires for the Toyota Land Cruiser Prado with size 245/60 R20?
You can try checking online platforms like Amazon or eBay, where you might find a variety of tire sizes, including 245/60R20. Additionally, consider visiting specialized tire shops or larger automotive supply stores in your area, as they might have a wider selection. Sometimes, contacting the tire manufacturers directly can also help you locate a dealer that stocks the size you need.
You can consider upgrading the wheels on your Subaru Liberty Wagon to a larger size to prevent scraping against the chassis and front end. Typically, people upgrade to 17 or 18-inch wheels for better clearance and aesthetics. However, make sure to check for compatibility with your vehicle's suspension and wheel well space, and consult with a professional to ensure safety and performance.
Hi everyone, can the Sharan fit 245/45/18 tires?
Why does the specification on my tire sidewall say 215/50/17 instead of 205/50/16? The current tires on the wheels are 215/55/17. It's a 2016 automatic comfort model produced in 2019.
If you're considering buying an RDX, it's generally recommended to look for models from recent years as they tend to have the latest safety features and technology. When choosing between a two-wheel drive (2WD) top trim and a four-wheel drive (4WD), it depends on your driving conditions. If you're mostly driving on highways and in urban areas, a 2WD might be sufficient and could offer better fuel economy. However, if you want extra traction and stability, especially in adverse weather conditions, a 4WD would be a safer option. In terms of safety, newer models typically have more advanced safety technologies. Always check the specific safety features available in the model year you're considering.
When driving on the highway, if the steering wheel starts vibrating when you exceed 100 km/h and the vibration becomes more pronounced at 120 km/h, it could indicate a few potential issues. It might be related to wheel balancing, alignment, or tire issues. You might want to have these checked by a professional to ensure safety.
Jeep Jeep Wrangler
Jeep WranglerAED 144,900 ~ 399,999Gasoline & Petrol
