Is the front axle of the 2024 regular Rubicon a ball cage or a universal joint?
How much is a front axle for a Maxus T60?
Hey guys, the dust boot on the control arm ball joint is torn. Is it necessary to replace it? Will it have a big impact if I don't?
Hello fellow car enthusiasts, I own a Patrol Y62. A few days ago, while driving, the lower ball joint on the left rear wheel suddenly broke. Do you know what might have caused this?
4I've replaced the control arm ball joints, steering rack, and shock absorbers, but the chassis still makes a thumping sound. What could be causing this?
5Do you guys often scrape the chassis when driving? Is it necessary to choose a front axle lift?
6Is the new 212 equipped with solid axles both front and rear?
7What does it feel like to handle a vehicle with front and rear rigid axles on the highway?
8Is the ambient lighting in the 2024 Villa Pro only in the front row or in both the front and rear rows? Mine only has it in the front row.
9Is the front axle of the 2024 regular Rubicon a ball cage or a universal joint?
10Is the S series not coming out in 2024? I see that the 2025 models are gradually being released, and for 2024 there are only the regular and GTS versions.
