عمر جواد
2024-09-13 11:40
I've driven my 2024 Wrangler for 10,000 kilometers. The first service was done at the 4S shop at 5,000 kilometers. They suggested I service it again at 10,000 kilometers. Do I need to change the engine oil this time?
سعود دليل
سعود دليل2024-09-13 14:38
For maintenance, you need to change the engine oil. It's recommended to do the second maintenance at 15,000 km; there's no need for the second service at just 10,000 km.
I last changed the oil in August last year and have driven less than 10,000 kilometers since then. Do I need to change the oil now, and what's a good type to use?
Guys, has anyone had to replace their steering gear? I changed mine after just over 5,000 kilometers, and now it's making noise again. Every time I turn, there's a cracking sound! Is this a common issue? The warranty is about to expire, and if it happens again, I'll have to pay out of pocket. It's really frustrating.
Hello fellow Wrangler owners! How many kilometers should I go before changing the spark plugs on a 2.0T JL Wrangler? And which brand do you recommend? Thanks for the suggestions!
Is the first maintenance time for Kia Seltos 6 months or 5000 kilometers according to the 4S dealership?
I've got a T-Roc 1.5T for about a year now, and did the first service at 4,000 km. The dealership said the second service is due either after a year or at 10,000 km. Now it's at 11,000 km, and I'm feeling that the low-speed acceleration isn't smooth. Should I just go and change the oil outside? The dealership mentioned that 10,000 km is too long.
Folks, I don't drive much. I did the first maintenance within three months, and it's been over half a year now but I haven't driven 5,000 km yet. When should I do the second maintenance?
Yesterday, I went for the three-year warranty and maintenance. The after-sales service suggested I change my tires, saying the treads are almost worn out. I've driven 56,000 kilometers. How many kilometers did everyone else change their tires at? Has anyone switched to different tires? Continental is really too expensive for me. Are there any high cost-performance alternatives?
Jeep Jeep Wrangler
Jeep WranglerAED 144,900 ~ 399,999Gasoline & Petrol
