How often do you guys change your oil? I did my first oil change after over 6000 km, and then again close to 12000 km. I drive 80% on highways and the rest in the city. I always refuel with PetroChina and Sinopec. After a recent trip of over a thousand kilometers on the highway, I felt the accelerator wasn't as responsive, so I changed the oil again.
Should I change the transmission oil for a 2019 GAC GS5 270 Premium Edition with 60,000 km?
Yesterday, I went for a car maintenance, and the oil draining took a bit longer. The mechanic said that adding just over 4 liters of oil wasn't enough, so they added a bit more, totaling 5 liters. Is this reasonable?
I have a 2019 manual Rapid with just over 50,000 km. At 120 km/h on the highway, the RPM is around 3100, and I feel the engine noise is too loud. What RPM do you guys get when driving on the highway?
4Is it necessary to change the transmission oil if there's occasional delay and jerkiness when shifting at 35,000 km over 3 years?
52020 top model, currently at 120,000 km. Started burning oil shortly after changing the belt at 100,000 km! Anyone else experiencing the same issue? 🤦♂️
6The car starts to shake after reaching 120 km/h on the highway.
7Why is it indicating that I need to change the oil again when I just changed it in March?
8How often do you guys change your oil? I did my first oil change after over 6000 km, and then again close to 12000 km. I drive 80% on highways and the rest in the city. I always refuel with PetroChina and Sinopec. After a recent trip of over a thousand kilometers on the highway, I felt the accelerator wasn't as responsive, so I changed the oil again.
9Do you use fully synthetic or semi-synthetic oil for your 10,000 km oil change?
10Has any car owner felt that the car's power decreased after changing to alloy wheels?
