عبد العزيز مهدي
2024-08-25 19:22
For a 2024 Jeep Wrangler Sahara that's already fitted with 285 tires, but still feels small, what size wheel spacers would make it look more impressive?
فهد جمال الدين
فهد جمال الدين2024-09-23 16:00
I also want to change it.
20
عمر ناصر
عمر ناصر2024-08-30 07:26
Indeed, having tires that stick out more does give a wilder and more muscular look. 😁 I directly changed the rims with a smaller ET value, and the stock 255 road tires now sit flush with the body, which looks much better. I feel like the car's stance is much more stable now. I haven't tried adding spacers because I'm worried some small shops might not install them properly, which could be unsafe. I want to ask if you need to reprogram the computer when you switch to 285 tires? I'm also planning to change my tires.
20
Can the GV80 fit a full-size spare tire?
I have a 2018 Outlander 2.4 AWD. Last month, the right front wheel got hit, and I had to replace the shock absorber, half shaft, and steering rack. 😒😒😒 Now, when I'm driving at around 110 km/h, the steering wheel vibrates in my hands. It's not exactly a shake, but more of a tingling feeling. The car doesn't drift or vibrate, just the steering wheel. If I grip the wheel tightly, it feels a bit better. There's no issue when driving below 100 km/h. I've done wheel alignment, and the data is spot on. I've also done wheel balancing and swapped the front and rear tires. I've even replaced the front bearings, but there's no change. The repair shop said the next step would be to start replacing parts one by one, but that would be too costly. Does anyone know what the problem might be? I'd be willing to offer a small reward for a solution. 😏😏😏
Hi everyone, I'm considering buying a Jeep Compass around 14.15. I'll use it for daily commuting. Is the only difference between the 2.0 and 2.4 models the two-wheel drive and four-wheel drive? Which one would be more suitable for me?
Guys, can you buy a spare tire for the 2008 model and put it in yourself? Will it fit?! What size should you get?
Can a Defender be fitted with 285 wide tires?
I'm 44, looking for my first car, living in a small city. It's for daily commuting and family use. Between the Mazda CX-5 2.0 top trim and the Kodiaq 2.0T two-seat luxury version, which one would be more suitable?
It sounds like you are experiencing a vibration issue with your vehicle, especially noticeable at certain speeds. After performing wheel balancing, the shaking became more pronounced between 100 to 110 km/h, even reaching the seats, but it disappears at 120 km/h. You also mentioned that at low speeds on uneven cement roads, there is a resonance from the engine compartment to the steering wheel. These symptoms might indicate an issue with the wheel alignment, tire condition, or suspension components. It would be advisable to have a professional mechanic inspect the vehicle to diagnose and resolve the problem accurately.
This car is already six years old. Not sure how many more years it can last, as small issues are increasing and fuel economy is getting worse. The resale value is very low.
I have a 2024 model with a 2.0 engine, and after modifying to a quad exhaust, there's a resonance between 2000-2400 RPM. It's more noticeable at high speeds, and the sound seems to come from the right rear exhaust in the cabin. Has anyone experienced something similar? The issue persists even after removing and reinstalling the exhaust tips, so it's not due to loose fittings.
Jeep Jeep Wrangler
Jeep WranglerAED 144,900 ~ 399,999Gasoline & Petrol
