علي رومي
2024-11-27 17:25
Can I use 4H part-time for extended periods in snowy conditions? Should I avoid sharp turns?
سلمان أمين
سلمان أمين2024-11-28 21:25
4H AUTO is fine. It's still rear-wheel drive, but will switch to four-wheel drive when needed.
عمر تركي
عمر تركي2024-11-27 22:04
If you don't have 4A, be cautious. With 4A, the front and rear are typically soft connections, while without 4A, they are usually hard connections.
عبدالرحمن عماد
عبدالرحمن عماد2024-11-27 21:27
Drive casually, it's not that fragile.
I'm looking to buy a 2018 Land Cruiser 4000 in good condition. Mileage doesn't matter, but I want to avoid dealerships. 🤦‍♂️🤦‍♂️🤦‍♂️
What mode should I use for my Jeep Grand Cherokee in snowy and icy weather?
How can I manually turn off the air conditioning? I always have to tap on the screen to turn it off.
Why is it still using a part-time 4WD at this price? At the very least, it should have full-time 4WD with a lock.
When I use the air conditioning for a longer time in the summer of 2019, the cold air stops blowing inside the car. Does anyone know why?
What should I do if I don't use my car for a long time?
Hey guys, how do you avoid the small battery draining and getting error codes when tinting? Should I keep the car running or turned off? I noticed that the car doors are open during the tinting process.
Why does the turn signal blink multiple times when I step on the brake and turn?
There's a bug in the fuel consumption mileage stats of the Nissan X-Trail EP, which causes it to reset automatically. This has happened a few times, and each time all the data on the "Since Last Refuel" page gets cleared. I'm not sure if it's a bug. It's still hard to pinpoint the exact conditions for the issue to reoccur, but I can confirm it should include the following: 1. Long periods of idling without turning off the engine 2. Unlocking the car doors 3. Leaving the car with the key (out of sensing range) Then, when you return, you'll find the data has reset. This has happened three times, and looking back, it was pretty much under these circumstances.
What gear do you use when driving up a long incline for an extended period? [Grinning] Share your experiences.
Jeep Jeep Wrangler
Jeep WranglerAED 144,900 ~ 399,999Gasoline & Petrol
