إسحاق نايف
2025-02-18 10:56
What are the most important regular maintenance tasks needed for a Hyundai Accent ?
محمد رأس2025-02-28 17:37
look, the most important thing is to change the oil every 5,000 to 10,000 km, depending on the type of oil. Also, make sure to replace the oil and air filters on time. Don’t forget to check the brakes and fluids regularly to avoid sudden issues.
شعبان سلمان2025-02-28 17:37
the most important thing is to take care of the oil and filters regularly. Don’t wait until they start causing problems. Also, check the transmission and AC, especially if you drive long distances, so you don’t run into issues later.
What maintenance is needed for a vehicle at 40,000 kilometers?
Is a 2012 Hyundai Accent worth buying for 2,160?
Do I need to read data and match the computer when changing the battery in a Hyundai Accent? I replaced the old battery myself and directly installed a new one. Is that okay?
4Is it possible to buy an automatic Hyundai Accent for 8000 RMB?
5How to connect Bluetooth on a Hyundai Accent?
6What is the normal fuel consumption per 100 kilometers for a 2010 Hyundai Accent with a 1.4-liter engine given the current fuel prices?
7Does the Hyundai Accent have a tire pressure monitoring system?
8Hey guys, what's the regular maintenance interval?
9What maintenance is needed at 60,000 kilometers?
10Can I go to the Hyundai 4S shop for maintenance? 😂
